What is this? I just setup my raspbery pi and this little color block keeps appearing during movies. Does it indicate something?
Little color block upper right corner
jglazer63 -
July 28, 2016 at 8:21 PM -
It does indicate that your power source is not delivering enough power.Please consider changing it for a beefier one. Preferably 2 A or higher.
Ok I plugged it into a 2.5A adapter (from my tablet) and the little color box is still there. Any other ideas?
Post your Kodi Edition Raspberry Pi Cases here
If it's the under-voltage warning it means the power supply is not providing stable 5 volts and you'll need a better one. Btw. the amount of power (Ampere) it can provide has nothing to with the voltage stability, you can even have a 20A adapter with unstable voltage.
- Official Post
I don´t know where you are from. But here is one that should fit:
Rydges SpeedPower High-Quality PC Netzteil 5V 2,5A: Amazon.de: Elektronik
