Everytime I‘m updating 9.x my audio device get‘s reconfigured to a wrong device. I configured my HDMI device, but on every update it switches to alsa device. That means I have no sound after the update. It already happened from 1208 to 1210 and now again on 1210 to 1213.
LE9: Audio device on every update reconfigured / no sound
marc.bau -
December 16, 2017 at 7:37 PM -
- Official Post
You're using pre-alpha builds. If you want stability use 8.2.x
I was told to upgrade because of the many changes in pvr and to verify if bugs are fixed. 8.x is totally unstable. Only cvh 8.2 bild is stable. LE 8.2 is broken since every release after 7.90.010.
- Official Post
That's very helpful thanks. Why not file bug reports instead? Everyone else says 8.2 is rock solid
This is a bug report. That is why it was reported in development > bug reports.
- Official Post
You should file it at the Kodi forums. We simply consume their application.
Just updated from Build 1213 to 1231 and this reconfiguration has not happened again. Is this a known change or just luck?
