Volume Amplification does not work
  • Hi,I noticed that the Volume Amplification does not work in video player, i am watched Movies with AC3-6ch, AC3-2ch, mp3 audio, sometimes I had to make the sound louder , but there is no response to the movement of the slider of Volume Amplification in KODI ( probably OMX Player ).
    I have Raspberry PI1 B with HDMI output to TV.
    I tried 7.0 and 7.02 releases, but Amplification has never worked.
    In OpenElec or OSMC this feature works correctly.
    I hope you fix this bug in the next release.
    Sorry for my poor english.
    Edited once, last by kvoko (July 21, 2016 at 9:41 PM).
  • Do you have passthrough enabled? (That will stop amplification from working).
    Does it work better with omxplayer disabled?
    Hi,
    I have not touched standard audio settings in KODI, passthrough is disabled of course.
    As far as i know, on RPi1 OMX Player cannot be disabled. In my Video Settings both
    items: Hardware Acceleration OMX/MMAL are turned on. ( same as in OSMC/OpenELEC ).
    I'm not sure if this has anything to do with the sound.
    Edited once, last by kvoko (July 22, 2016 at 5:44 PM).
    If you disable OMX acceleration in video settings, then it seems to work. Otherwise, the amplification setting has no effect.
  • Try messing with the audio output configuration in the audio decoder section of settings > system. Diddling with them made mine work, currently set to "optimized".
