With the last update you need to add a version to the mount file
the mount server is windows 2012 r2 so that should be 3.02
but it still wont'work
is there anything wrong with the file ?
It Always worked liked a charm before
(code=exited, status=255)
QuoteDisplay More[Mount]
# The share we want mount
What=//http://XXX.XXX.XXX.XXX/Rom/kodi/nes# Where we want mount this share
Where=/storage/roms/nes
# Any options you usually use with the "-o" parameter in the mount command
Options=username=XXXX,password=XXXX,rw,vers=3.02
# filesystem type
Type=cifs
