Wifi Setting with LibreELEC
  • I can't see the wifi option for my S905X device under LibreELEC settings. What is the solution?
    Thank you for your answers.
    Highlights:
    Operation System: Android 6.0 OS
    CPU: Amlogic S905X Quad-core 64bit Cortex-A53 up to 2.0GHz.
    GPU: Penta-Core ARM Mail-450.
    3D Function: Hardward 3D Graphics Acceleration.
    RAM: DDR3 2GB; FLASH: 8GB (EMMC).
    Expand Memory: Micro SD Card (Maximum support 64GB).
    Ethernet: Supports 10 / 100Mbps Ethernet. Standard RJ-45.
    Wireless Connection:
    WIFI: Support 2.4G Wi-Fi. And support Wi-Fi Hotspot, could be as a wireless router.
