Is Auto Calibration using a RPi 3 Possible ?
  • Hey guys,
    I am using libreELEC on a Raspberry Pi 3. As I switch between two different monitors (one at work then one back home), I have to reset the screen calibration to fit the TV.
    Is there a way to auto calibrate the screen in order to adapt to every monitor ?
    Any help is appreciated.
  • Always try to avoid using the calibration in Kodi.
    Ideally when playing 1080p video on a 1080p display the pixels will be unscaled.
    Using calibration will resize the video on the way out and then the TV will resize it back again resulting in a lower quality image.
    Just disable overscan on your TV/monitor and calibration shouldn't be required resulting in a better quality image and no switching issues.
    Check the menu options on TV (it may be called "just scan", "screen fit", "HD size", "full pixel", "unscaled", "dot by dot", "native" or "1:1").
