tvh2kodi addon - configure tvheadend from kodi interface
- edit4ever
- Thread is Unresolved
belaid38 - Is the functions you want added under the CONFIGURATION > DVB INPUTS > SERVICES tab? If not, which tab are they located under on the web interface?
I want to make sure I'm looking at the correct functions you want to edit - as they aren't used here in the US, so I'm not familiar with them.
belaid38 please provide information on where the configurations you want added are found.
For example, are they found in the mux settings? Service settings? Network settings?
As I only use ATSC in the US - I need a little bit of information so I can sort out where to get and put the functions you want to edit.
Thanks!
Thanks!
edit4ever She lacks these things
Perfect - thank you. I will add these functions and hopefully have an update for you in a day or two!
belaid38 I need your help with part of this. Since I don't have access to DVB-S adapter, I can't see the configuration screen for that device.
Can you please put the following url into a browser:
Then you'll get a json response - you are looking for the uudi of your DVB-S adapter. Form your screengrabs, you only have one adapter - so just look for the uuid part - then copy the long number that appears after "uuid":
Don't copy the quotes. Then put this url into your browser - replacing THE-UUID-NUMBER with the number you copied from above:
Then send me that response - you can PM me here.
If you have any questions or issues - let me know.
Thanks!
Thanks! I'll let you know when the test is ready.
belaid38 OK - I've got a bunch done - but there is a part here that will be a bit more difficult to complete without having a dvb-s adapter. You show in your screengrabs that the dvb-s adapter is set as a 4-port switch - which brings up a different panel in the UI. I'm not sure how to access that panel - as the higher level config screen for the adapter itself is the info I had you send to me. I can create that config - but need to understand the link between those two screens. (ATSC-T, ATSC-C, IPTV, DVB-T, DVB-C all use one level of configuration for adapters)
In order to sort his out - can you let me know if you are familiar with using the inspect tool in the web browser? I may need to have you grab some additional information so I can see how tvheadend uses the api to get between those configuration levels.
How can I help my brother? I didn't understand what you mean
perfect - thanks!
I won't be able to work on this until later tonight...but I think I have what I need to add all the functions you requested.
