Virtual Compiling Problems
  • I'm trying to compile Virtual to use on my ESXI server to replace a KODIbuntu installation. This install is used strictly for maintaining the library for my network.
    xQEHM
    Am I able to compile without the joystick compatibility? I don't think my installation requires it, but I understand it may be a dependency.
    I did a couple searches for this prior to posting and wasn't able to come up with anything. If I missed something, Please point me in the right direction!
    Thanks for any advice!
  • Quote
    wget: Unable to resolve host address 'github.com'
    wget: Unable to resolve host address 'sources.libreelec.tv'
    This doesn't show you some DNS issues you have on a build machine? You will not build anything until you fix this.
  • This doesn't show you some DNS issues you have on a build machine? You will not build anything until you fix this.
    Aw man. I guess for some reason I figured it was an issue on the other end as everything else had downloaded ok up to that point. Added google DNS to my resolv.conf and it appears to have gotten past that! Thanks for the help.
