Hi all,
Can you please assist to install LE from the SD card on Nexbox A95x, S905 Android 5.1 version. This is the 2GB/ 16GB device. I created the SD card with Rufus and also with the LE Tool but i am getting E:Cannot load volume /Misc using both method. LE image build i tried are LibreELEC 8.0 J and LibreELEC 8.0 K. converted the device tree also to dtb.img and copied it to the SD card.
I have two of these Nexbox A95x, S905 boxes and am getting the same E: Cannot load volume /Misc error when using the tootpick method. Tried also to go into recovery using the terminal emulator but still i cannot boot into LE.
Can you please help me fixing the Cannot load volume /Misc??
