Heureka!
That works like a charm.
Thanks to both of you!
Is there any chance this patch can find its way into the official package?
Heureka!
	mglae do you like to pr it or should I do it ? (I don't want to snap your copyright  )
CvH thanks for the testbuild. I only liked to avoid an untested PR.
Fix should be available at add-ons.
Tx mglae
Hello Funny People, you know what I am Happy, It's working with version 8.2.105 of Multimedia tools Addon
Thanks a lot
I add thread status to solved
Hi !
I'm having the same problem with the latest build from Kodi 18 and Multimedia Tools 9.0.108 :
LibreELEC Testbuilds for RaspberryPi (Kodi 18.0)
Any solutions ?
Thanks !
what is the same problem ?
Sorry I tough it was clear.
When squeezelite launches, it complains about missing libraries :
LibreELEC (Milhouse): devel-20181003210259-#1003-gf262797 (RPi2.arm)
ViELEC:~ # squeezelite -n visqueeze22 -d all=debug -m ab:cd:ef:12:34:59
[09:09:52.649541] stream_init:294 init stream
[09:09:52.649913] stream_init:295 streambuf size: 2097152
[09:09:52.652812] output_init_alsa:937 init output
[09:09:52.652980] output_init_alsa:977 requested alsa_buffer: 40 alsa_period: 4 format: any mmap: 1
[09:09:52.653057] output_init_common:347 outputbuf size: 3528000
[09:09:52.653146] output_init_common:371 idle timeout: 0
[09:09:52.665554] output_init_common:411 supported rates: 384000 352800 192000 176400 96000 88200 48000 44100 32000 24000 22500 16000 12000 11025 8000
[09:09:52.673855] output_init_alsa:1003 memory locked
[09:09:52.674502] output_init_alsa:1026 set output sched fifo rt: 45
[09:09:52.674516] output_thread:685 open output device: default
[09:09:52.674598] decode_init:153 init decode
[09:09:52.674987] alsa_open:349 opening device at: 44100
[09:09:52.684261] load_faad:593 dlerror: libfaad.so.2: cannot open shared object file: No such file or directory
[09:09:52.685254] load_vorbis:289 dlerror: libvorbisidec.so.1: cannot open shared object file: No such file or directory
[09:09:52.685974] load_flac:248 dlerror: libFLAC.so.8: cannot open shared object file: No such file or directory
[09:09:52.686035] register_pcm:433 using pcm to decode aif,pcm
[09:09:52.686720] load_mad:365 dlerror: libmad.so.0: cannot open shared object file: No such file or directory
[09:09:52.686783] decode_init:187 include codecs:  exclude codecs:
[09:09:52.687206] discover_server:826 sending discovery
[09:09:52.688143] discover_server:837 got response from: 192.168.0.2:3483
[09:09:52.689560] alsa_open:420 opened device default using format: S32_LE sample rate: 44100 mmap: 1
[09:09:52.689970] alsa_open:511 buffer: 40 period: 4 -> buffer size: 1764 period size: 441
[09:09:52.691435] slimproto:925 connecting to 192.168.0.2:3483
[09:09:52.692104] slimproto:964 connected
[09:09:52.692161] sendHELO:138 mac: ab:cd:ef:12:34:59
[09:09:52.692190] sendHELO:140 cap: Model=squeezelite,AccuratePlayPoints=1,HasDigitalOut=1,HasPolarityInversion=1,Firmware=v1.9.0-1098,ModelName=SqueezeLite,MaxSampleRate=384000,aif,pcm
[09:09:52.707587] process:526 strmAm I the only one with this issue ?
awiouy ^^^^
#3062 should fix it.
It's solved ! Thanks
