As in when you go to sound settings during playback, and you can boost the dB level, is there a way to set a default boost, as I need to have my TV up very high and if I switch back to another source from the Pi, it blows me across the room ![]()
TIA.
TIA.
There should be a button at the bottom that says "use these settings as default" - or similar to that.
No way! Is it that easy? 😀
*hides under Rick*
You were dead right, dunno why I never noticed it.
I am on digital output and I have to use my surround receiver's remote to adjust volume in movies.
