[SOLVED]Refresh Rate Problem
  • Is it possible to add or force a 50HZ refresh rate when not listed under Settings > System > Display?
    I have an Intel Celeron and a AMD E450 Nettop PCs and with any version of LibreElec including 8.0 both only offer the refresh rates 23.98Hz, 24Hz & 30Hz at 1080p resolution when connected to my Sharp TV. The same PCs offer the full range of refresh rate up to 60 Hz when connected to other TVs at 1080p
    If I install Windows on the same PCs connected to the Sharp TV the full range of refresh rates are on offer up to 60 HZ at 1080p.
    If I install Linux (Ubuntu) on one of the PCs I am only offered 23.98Hz, 24Hz & 30Hz at 1080p resolution so looks like a Linux problem!
    However my RPi2 running any version of LibreElec connected to the Sharp TV at 1080p, 50Hz refresh is one of options.
    Chris
    Edited once, last by jcjefferies (February 26, 2017 at 12:29 AM).
  • First what is the TV model and how is it connected, HDMI?
    With the TV powered on and connected to your PC, can you SSH and copy/paste the output of the following command
    xrandr
    Edited once, last by vitorp07 (February 23, 2017 at 4:59 PM).
  • TV is Sharp LC-40sh340K
    HDMI connection. Both HDMI behave the same
    libreelec:~ # xrandr
    Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
    DP1 disconnected primary (normal left inverted right x axis y axis)
    DP2 disconnected (normal left inverted right x axis y axis)
    HDMI1 disconnected (normal left inverted right x axis y axis)
    HDMI2 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 890mm x 500mm
    1920x1080i 60.00*+ 50.00 59.94
    1920x1080 24.00 23.98
    1280x720 60.00 50.00 59.94
    1440x480i 59.94
    720x576 50.00
    720x576i 50.00
    720x480 60.00 59.94
    720x480i 60.00 59.94
    640x480 60.00 59.94
    VGA1 disconnected (normal left inverted right x axis y axis)
    VIRTUAL1 disconnected (normal left inverted right x axis y axis)
    libreelec:~ #
    Thanks Chris
  • EDIT: on your TV's manual it says the HDMI connector supports 1080i only not 1080p so if that is correct(could be a typo) if you select 1080p in Kodi Display settings this is probably why you only get to choose 30Hz
    SSH and try this below. (where "50.00" is you could put "60.00" if you want)
    xrandr --output HDMI2 --mode 1920x1080 --rate 50.00
    If it does work properly SSH again and do these command below, be sure not to change the HDMI port used "HDMI2".
    echo "#!/bin/sh" > /storage/.config/autostart.sh
    echo "xrandr --output HDMI2 --mode 1920x1080 --rate 50.00" >> /storage/.config/autostart.sh
    Edited once, last by vitorp07 (February 23, 2017 at 6:41 PM).
  • Thanks! Unfortunately all the command does is remove the 1080p x 30Hz option in Kodi!
    Checking the TV manual the HDMI connections are supposed to support 1080p at 24Hz, 50Hz & 60Hz.
    The TV displays the resolution for about 1/2 second and the RPi2 running LibreElec 8.0 is definitely running at 1080p x 50Hz as set in Kodi.
    I now have memories of using xrandr and cvt to define a resolution a year or two ago. All I can think is that before I discovered OpenElec I was using Kodi on Ubuntu and had this same problem on the two nettop clients. Unfortunately neither cvt or gtf seem to work on LibreElec to produce the modeline.
    For comparison this is output when my old original Kodi Pentium4/Nvidia 210 Video client is connected to the same TV which runs at 1080p x 50Hz.
    LibreELEC (official) Version: 7.0.2()
    LibreELEC6:~ # xrandr
    Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 8192 x 8192
    DVI-I-0 disconnected primary (normal left inverted right x axis y axis)
    VGA-0 disconnected (normal left inverted right x axis y axis)
    DVI-I-1 disconnected (normal left inverted right x axis y axis)
    HDMI-0 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 890mm x 500mm
    1920x1080 60.05 + 59.94 50.00* 23.97 60.00 50.04
    1440x480 60.05
    1280x720 60.00 59.94 50.00
    720x576 50.00 50.08
    720x480 59.94 60.05
    640x480 59.94 59.93
    LibreELEC6:~ #
    I have only just noticed that my satellite set top box connected to the other HDMI connection runs at 1080i but there is no option to change this in the box setup. The simple work around seems to be to resort to 1080i x 25 Hz as I cannot detect any problems with the picture and the TV detects it as 1080i x 50Hz.
    Thanks for the help
    Chris
