[Resolved] Remote does not respond for 10 seconds after sleep
  • Hi there,
    I have a strange one that appeared in Kodi 15 (OpenELEC) and has followed me to Kodi 16 (clean build LibreELEC) and now Krypton with a Millhouse build. My hardware in an ION2 based Zotac Zbox that I've been using Kodi on for 4+ years. I have a Harmony Hub remote and I run a remote.xml file in the userdata/keymap location to remap the teletext buttons for library updating and cleaning (have tried deleting this and makes no difference). The remote receiver is an official RC6 one that is registered on the device as an eHome one.
    Now to the problem...
    If I sleep the device overnight (or for an extended period that I have not defined yet), the remote control does not respond for 10 seconds almost to the second. After 10s, everything works fine. If I then sleep the unit again but restart it 2 minutes later, there is no 10s delay which is weird. It only appears to happen after an extended nap! I have installed a remote debug xml file in the keymap location and confirm that the device is receiving the commands in the first 10s, at least after various sleep/wake cycles. I can't say I've dropped the remote debug file overnight but I'll try that tonight.
    It's driving me nuts as it does not have a great W.A.F when that happens. The question is, how the heck do I debug that as I only have a few seconds to run commands after wake from sleep?
    Input logfile here. Let me know if there are other logs I should upload.
    Edited once, last by xbmcnut (June 1, 2016 at 2:27 AM).
  • Have confirmed it's the Hamony activity causing the problem. If I manually start all appliances and use a RC6 media remote, there is no delay. LE is controlled on the Harmony by adding the device as a Microsoft Media Center SE which has always worked. I'm now removing the device and I'll re-add it as something else to see if that cures the problem.
