Hello,
I have installed the 7.0.2.009 build on to my OTT MXQ pro 4k and some buttons on the remote are not working. I tried using WinSCP to delete and copy over the remote.conf to the /flash folder. Every time that I try I get an error. Is there another program that I can use to remove the remote.conf and replace it? What could be causing this error?
Thank you
