- Official Post
Will test comskip now.
if you have it working it would be nice if you could post used cmd lines and configs, could help other users too because like said I have 0,00 idea about it ;D
Considering trsqr's OE implementation you might not need to specify the .ini path and don't need the quotation marks for the %f parameter:
Open your TVheadend web interface and go to tab Configuration -> Recording. Make sure the following is configured:
- Remove all unsafe characters from filename: YES
- Replace whitespace in title with '-': YES
- Post-processor command: /storage/.kodi/addons/tools.comskip/bin/comskip %f
Short question: comskip seems to work as files are generated. I don't see ongoing/finished recordings in KODI anymore, though. (Kodi 17.3 on Win 10 + Kodi/SPMC 17.3 on Shield TV). Is there a new client version needed? B/c TVHClient on Android has no trouble listing these recordings.
yea great idea, he basically fakes the comskip binary with an bash script that includes all commands, pretty good idea  will adjust it
 will adjust it
yes, afaik there are problems due the new Tvh version
Now I remember why I ditched comskip a while ago. It just won't do the autoskip from the recordings view. Only seems to work from files menu with both .edl/.txt cutfiles. If anybody knows a fix, that'd be much appreciated.
if you play your recordings or what do you mean ?
Yes, if I play it from the recordings window. There was a fix for a supposed break in edl handling in 17.1 but I don't comprehend why it makes a difference whether you start it from Files or from Recordings. I walked back to 4.2 for now. Maybe I'll revisit in a few weeks.
Till now im running comskip on my windows desktop to search for comercials on the drive connected to Odroid-C2-LibreELEC.
It it true that we now can run comskip/LibreELEC on the same mashine? this would be really really interesting for me!
possibly yes, but idk if you need a lot cpu for it or not -> no idea if an odroid is fast enough
we could try...
it would be ok for me if the system is laggy a few minutes after the recorded movie, until comskip finished.
most time i only record if im not at home. so laggy system while the odroid is searching commercials doesnt matter (IMHO).
do you know how to try this? and in addition: how to trigger comskip automatically after a record stops/finishs?
/storage/.kodi/addons/service.tvheadend42/bin/comskip --ini=/storage/.kodi/userdata/addon_data/service.tvheadend42/comskip/comskip.ini "%f"
comskip ini needs to be adjusted
I change this in future version that you only need to insert comskip but currently this is the way it should work - like said i have not really a clue about comskip
i tried to test your newer versions of tvh but versions 4.3-291 and 4.3-295 did not work (got no access via webbrowser nor tvh-client).
I am using 32bit build from Raybuntu (Libreelec 8.2)
yea this is not working
i already expected this sort of answer  because you wrote this at the opening post of the
thread: Nightlies (currently only LE7)
but at Tvheadend nightly builds for LibreELEC you also have builds for LE8.
So this is only compatible with official (64bit) release? Or which version i can use for testing comskip?
because you wrote this at the opening post of thethread: Nightlies (currently only LE7)
ups forgotten to change this
currently only building for LE8
the problem is the 32bit, you can actually try if the WeTek_Play version work - ofc only for LE8 and possible not for 8.2 (never tried)
ok. thanks.
i will try
edit: same error as mentioned above
Follow Problem:
/storage/.kodi/addons/service.tvheadend42/bin/tvheadend: error while loading shared libraries: libvdpau.so.1: cannot open shared object file: No such file or directory
All relesaes after "Generic-tvheadend42-4.3-71" have this proplem.
Running on VMWare "LibreELEC-Virtual.x86_64-8.0.2"
Version 4.3-71 running fine.
Any solution for my problem to use the newer builds?
Oh, I have a look tx.
