May 21, 2016 at 3:08 AM #1 Hi folks,Am trying libreelec on a SolidRun CuBox with and i.MX6 processor. I'm using the latest install ( 7.0.1 ) and there's no option to select HDMI audio output.What have I done wrong?Cheers,Steve
May 21, 2016 at 7:11 AM #2 Where is no option? HDMI output should already be preselected by default.Update: Just tested the image and hdmi sound is set by default. As it should be.
May 21, 2016 at 8:11 AM #3 ok so what have I done so that it isn't an option? Would the fact that the setup I built it with had only a dumb monitor on the end make a difference?
May 21, 2016 at 9:03 AM #4 Quote from sholdowa setup I built it with had only a dumb monitor on the end make a difference O would say that's the reason.
