Thank you for this revelation, but thousands of other RPI-3 users will disagree with you. Perhaps you need to set the output selection properly in the Audio output section.
I've tried each option and none of them worked on AV
Sent from my BNTV450 using Tapatalk [hr] So apparently I just needed to adjust the volume. It's working now
