Odriod C2 USB Serial Module for Ambilight
  • Hi, I think you need to add this to the hyperion.config.json file :
    Note the lower priority on the framegrabber.
    I use this settings successfully but the leds are flickering ...
    Yeah, that is the problem i encountered originally which is why i used an Arduino clone to control the lights with a USB connection to the C2.
    Works great on Jarvis, but the serial module needed is missing from Krypton.
    Looks like SPI has apparently been sorted? - but i don't want to change my existing setup as it's a lot easier to unplug a USB than a bunch of wires ....:(
    Edited once, last by zenji2010 (January 3, 2017 at 12:25 AM).
  • How did you manage to drive the LED via SPI? Is there a step-by-step-guide? Installing and configuring Hyperion with LED connected as shown in the wiki did not work for me.
