At other platforms I can install midnight commander shell file manager addon. It's already implemented to system tools 7.0.102 addon, but S905 repository has only 7.0.100 and no Mc.
maybe with 32 bit version of le working it?
with 32bit I can install all addon from rpi because arm repo?
Thanks.
Midnight Commander and system tools 7.0.102
envagyok -
December 24, 2016 at 4:09 AM -
- Official Post
We never released an official S905 image for LE 7.0 so there are no add-ons in the official LE repo. Your image is using a custom repo so you need to beg/nag whoever created that release to update their add-ons. You cannot install RPi/RPi2 add-ons to an S905 device as they are compiled for another CPU type and architecture (arm, not aarch64).
I find from other forum, it working.
(tested with S905 64bit libreelec)
MEGA32 bit version from libreelec to S905 isn't arm build?
My 32-bit builds for S905 use LE repo addon for WeTek Play, you should be able to find Midnight Commander there. On 32-bit builds ARM addons will work (except those which bundle kernel modules), Aarch64 addons will not. I think I will switch to build-specific addon repository for my next 7.0 build.
envagyok Here's updated System Tools addon for 7.0 Aarch64: virtual.system-tools-7.0.102.zip
envagyok Here's updated System Tools addon for 7.0 Aarch64: virtual.system-tools-7.0.102.zipThanks Kszaq
