[x86-64] Minisforum UM790 Pro, no standby (kinda read on)
  • Short story, got a new TV, it has 4k HDR. So i'm trying to get Kodi working with HDR. Currently my linux mint install is a bloated mess, so trying to run LibreElec to make it easyier.
    But i can't get this device to go into standby/sleep when using LE, Mint works fine tho.
    i've tried setting this option in this post, but it doesn't help. [x86-64] Resuming from S3 (Sleep/Suspend)
    But the device still doesn't sleep, Dmesg says it going to sleep, when if you press the keyboard it "wakes up" and starts logging to dmesg again, but the power light stays solid and the display keeps displaying (tho it doesn' update the display)
    Not sure there is much else i can try, i've tried the 12.1 verion and say issue, and the nightly as well.
    I even from a random github fork that added "amd ryzen support" which seems to have fixed my USB3 dismount issue when i compile with the extra firmware bits
    Can any one point me further alone in my journey ?
  • Stranger still, if i have a usb disk plugged in, the light on the usb disk goes out (like it would when the system sleeps in linux mint) and then comes back on when i press keyboard buttons.
