no passthrough of Dolby TrueHD (Atmos) to Pioneer VSX-LX505 (other Dolby Audio passtrough works)
    I switched the receiver fron a Pioneer VSX-1131 towards a Pioneer VSX-LX505 and I am facing now an issue.
    Passtrough of Dolby TrueHD 7.1 is not working. The receiver identifes the auto as analogue stereo PCM and only some static noise /white noise is coming. So the stream is not recognised as valdid TrueHD audiostream.
    disabling passtrough leads to a working PCM sound.
    Passtrough of other sound quality (e.g. Dolby Digital 5.1) is working
    Strange: Passtrough of Dolby TrueHD 7.1 is working on the old VSX-1131.
    Therefore, I'm a bit annoyed because I don't know where to search the issue: in libreElec/Kodi, on the Hardware of my NUC or on the new Pioneer Reciever
    What I already tried out:
    • switching the HDMI cable
    • getting a TrueHD signal from a BluRay-Player to the Receiver --> worked
    do you have some hints, how to proceed for finding the root cause?
    🔹 System Details:
    • Device: Intel NUC Kit NUC6CAYH - Arches Canyon with Intel Celeron J3455, therefore GPU Mesa Intel HD Graphics 500 (APL2)
    • AV Receiver: Pioneer VSX-LX505
    • LibreELEC Version: 11.0.3 (kernel: Linux 6.1.38)
    • Kodi Version: 20.2 (Nexus)
    • Audio Output: HDMI (ALSA)
    Out of kodi-log, i do not find somthing strange. do you see some hints?
    with tese, I got also some edid informations out of the LibreELEC installation. Are these from the connected receiver or are these those which the Intel NUC can do?
    cat /sys/class/drm/card0-DP-1/edid > /storage/.kodi/temp/edid.bin
    edid-decode /storage/.kodi/temp/edid.bin
    Edited 2 times, last by jfzview (December 7, 2025 at 12:59 PM).
    one additional result:
    using exactly the same file (00023.m2ts from a dolby demonstration disk) on an USB-Drive, playing it from the bluRay Player, everything worked. from LibreElec (using a live version of 12.2.1) not.
    I should test it on exactly the same HDMI input port but else, I would say, the Pioneer receiver is principally working fine with this TrueHD input.
    So the root cause is either LibreElec or my NUC Hardware.
    However, it is still strange that it worked on the old receiver, so perhaps the new one is somehow stricter to it's input signal. Can it be an issue that now it is HDCP 2.3 compliant while the old VSX-1131 was only HDCP2.2 ?
    do you have any hint what could be done to get closer to the issue?
  • Tried now several things:
    • Windows2Go USB stick with Kodi 21.2 --> Passtrough did not work
    • Windows2Go USB stick with the Windows10-build-in VideoPlayer --> Passtrough did work
    • LibreELEC-Generic.x86_64-13.0-nightly-20251209-dd92255 --> does not boot (so I fear, only legacy is working here)
    • LibreELEC-Generic-legacy.x86_64-13.0-nightly-20251208-c5df4f6 --> does not have working ALSA driver
    • LibreELEC-Generic-legacy.x86_64-13.0-nightly-20251027-304555c --> same issue. TrueHD is not working
    therefore, i see, that the hardware (NUC and Receiver) has no issue as it works fine with the windows basic tools.
    And the issue seems to be in Kodi and not in LibreElec as it does not work neither in LibreElec nor in Windows
    unfortunally, it is still not working and is not adressed in LE13 yet
    any more hints?
