[Exynos] LE 13.0-nightly for Odroid XU4 no longer boots
  • I've confirmed the issue with the odroid-xu4 boot failure.
    It occurs starting with the following image:
    - LibreELEC-Exynos.arm-13.0-nightly-20250730-ecfa284-odroid-xu4.img.gz
    And it has been fixed in the following image:
    - LibreELEC-Exynos.arm-13.0-nightly-20251223-941298b-odroid-xu4.img.gz
    If my testing method is correct, both(boot fail and performance) problems appeared since v6.16.
    - 81e3bc35c1e59d75693062b45b05adae32210fe5 is booted
    - 821d827dba93b3ffe14ac40dfb7dbc33935b6eca is not booted
    - 821d827dba93b3ffe14ac40dfb7dbc33935b6eca + 2 fix commits
    (098bfdb6b51d06adf6285b63e21b71078ae1d497 + 0b4b7ecca0daabe90b39f7171c78c5a4840a41e1) is booted but wrong performance
    This topic is talked for the boot fail issue.
    I think performance issue will talk on new topic better.
    (Similar performance issue is also happened on Lakka.)
