[RPi2B] Invalid Key/WiFi issues with USB dongle
  • DHCP on LibreELEC 12.0.2 with connman (2.0) and iw (6.17) versions from master works.
    I had to patch some checksums and I've also pulled in iwd (for good measure) and nftables (marked as dependency of conman in master branch) along with a newer version libnftnl (needed by nftables). If anyone is interested, my I've pushed my changes to a separate branch in my fork.
    I'll (try to) test 12.0.2 kernel/drivers on master/nightly next.
  • LE 13 with the kernel from 12.0.2 works too, so it seems to be a kernel/driver issue.
    I have reset packages/devel/glibc/, packages/compress/xz/, packages/linux-drivers/, packages/linux/, distributions/LibreELEC/options and projects/RPi/devices/RPi2/linux/linux.arm.conf to the version from tag 12.0.2. I have also pushed these changes onto a branch too.
    So from what I can tell the issue seems to be caused by either
    1. Changes the LE project made between 12.0.2 and 12.2.1 to the (RPi2) kernel/drivers -- e.g. via (removal) of patches
    or
    2. Changes made upstream between kernel versions 6.6.70 (which LE 12.0.2 uses) and 6.12.56 (which LE 12.2.1 uses)
    As mentioned previously in this thread, LE has disabled the out-of-tree 8192CU drivers in the past. These would have been used for my chipset in the past (and seem to still be used under RaspberryPi OS).
    But those drivers were already disabled in 12.0.2 (and in 11.x too for that matter), so I don't think it's relevant here.
    Compared to 12.0.2, 12.2.1 further disabled RTL8192DU and RTL8812AU, but I would expect that this has no effect for my dongle, as these drivers are for different chipsets (at least based on their name).
    I'm not quite sure how to continue debugging at this point, perhaps someone has a good suggestion.
    I'll try disabling RTL8192DU and RTL8812AU on 12.0.2 next, to see if disabling them somehow causes the issue (again, i don't expect it too, but you never know).
    Edited once, last by GamerBene19 (February 13, 2026 at 5:40 PM).
  • So I've bit the bullet bisected commits that touched linux kernel, drivers and LibreELEC options between 12.0.2 and 12.2.1 with
    git bisect start '--' 'distributions/LibreELEC/options' 'packages/linux-drivers/' 'packages/linux'
    According to bisect, this is the first bad commit
    This is my bisect log
    1267bd8 and 5d1274f do not build (which is also mentioned in https://github.com/LibreELEC/LibreELEC.tv/pull/10247) so i skipped them.
    014e83d also did not compile at first due to a missing call_read_iter which is referenced in out-of-kernel driver RTL8192DU and was removed in kernel version 6.10. For my bisect I simply created this patch to get it compling.
    I have also opened a issue in the driver repo in case it is helpful to someone.
  • I'll try the different version of the rpi-kernel (rpi-6.{7,8,9,10,11}.y) next to narrow down when it breaks. Might be a few days until I report back though as I won't be home over the weekend.
