Options for streaming audio to or from LibreElec
  • Hi there,
    I have a couple of RPis and Linux boxes, one of which as an RPI 5 which includes a HifiBerry amplifier. This can support streaming to the device if I use Moode Audio for UPnP / DLNA, or Airplay, but not easily if using LibreElec. What are my options?
    1. Can I stream audio from LibreElec to a Moode Audio or other RPi?
    2. Can I stream audio to LibreElec with adaptations?
    3. Do any of the Linux options for streaming to / from support adjustments to latency in the way that Airplay does? (This would allow one box to play video, while another outputs the audio from the video that is playing.)
    Thank you for any general advice you can give on these questions,
    Jim
    Edited once, last by JimKillock (November 3, 2024 at 5:38 PM).
  • For your setup I suggest MPD, which has a client/server architecture. So you can stream in any direction.
    Some audio aficionados also use RPi/HiFiBerry for DSD playback:
    greenvorbisfan
    June 29, 2021 at 3:05 PM
