My TV shutdown via CEC stopped working properly when I set the shutdown function in Kodi to Suspend.
TV shuts down correctly about once in ten attempts. When I leave the TV On and wake up the system, the TV turns off and immediately turns on again.
When I reconfigure the CEC or set the default values, the TV turns off the first time (after suspend). After that, it doesn't turn off.
If I turn off system via shutdown instead of suspend, the TV shuts down correctly. Controlling the TV via CEC also works. Pulse-eight has the latest firmware. I have tried all possible bios settings(S suspend states), but nothing helps. Please help.
I use pulse-eight with asrock N100M motherboard (intel n100) libreelec 12.0.1.
