Hi!
I have installed the podman addon on my raspberry pi 4B. First it didn't work at all because it claimed that /storage/.kodi/addons/service.system.podman/etc/containers/policy.json was missing. After I created that file manually podman pull and podman create worked but I can't start or run any containers because the following error:
Error: netavark: failed to start process: fork/exec /storage/.kodi/addons/service.system.podman/bin/netavark: exec format error
I have checked netavark binary and noticed that it is the x86-64 instead of ARM aarch64
- /storage/.kodi/addons/service.system.podman/bin/netavark: ELF 64-bit LSB pie executable, x86-64, version 1 (SYSV), dynamically linked, interpreter /lib64/ld-linux-x86-64.so.2, BuildID[sha1]=b90cc4c779a4cce1701e6a2071b07d300bc0775b, for GNU/Linux 3.2.0, not stripped
Can someone please fix this? I would rather use podman instead of docker but currently this addon does not work for aarch64 architecture.
Thank you ![]()
