  • My model is the same as yours, mine is 2 + 8 configuration
    Unable to get IP for wired Ethernet
    Did you solve it in the end?
  • U
    Hi, thanks for this.
    I own a MXIII-G Box and just installed
    LibreELEC-MXIII_Plus.arm-LE9-Kodi_18.5.img.gz
    All works great except one problem... When I press Stop on a video everything freezes and I have to pull the power from the box to shut it down.
    Any ideas?
    I have the same problem. I can't understand if there is a solution. If there is please explain to me in more detail. My box is a Tronsmart TV BOX MXIII Plus 2GB OS 5.1.1. Thanks in advance :shy:
  • please help libreelec for this m8s working box.
    Next time please use a translator because the only accepted language on the forum is English.
    dtech
    February 7, 2021 at 2:33 PM
    Unfortunately, I don’t see exactly the type of wifi chip on your photo, but basically one of two images can be good:
    • Universal n200: Ampak AP6330 or Realtek wifi,
    • OTT M8S+ (n200C): multiple broadcom/ampak wifi.
    Please try them out and report back in the linked topic.
  • Hello everyone. I dug up my old TV-BOX MXIII (S802 2/8 100) and decided to get some use out of it. I tried different firmwares, some didn't start, the preparation screen and constant restart, some didn't work at all and I only saw the incessant Android robot, some worked but there was a problem with the network). The LibreELEC-Universal_k200_2G.arm-9.2.8.16.img.gz firmware worked. I even managed to install Roon Bridge via SSH. The installation was from an SD Card and then transferred to MMC using the installtointernal command.
