LE 12b2: IPTV streams stutter when piped with ffmpeg
    I have the same problem with IPTV simple addon (not sure how to check what are my provider streams, FFMPEG or what) but exactly the same behaviour, since upgrade to LE12
    log
    2024-06-11 00:48:32.054 T:3234     info <general>: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder aac
    2024-06-11 00:48:33.575 T:3234     info <general>: CVideoPlayerAudio::Process - stream stalled
    2024-06-11 00:48:38.585 T:3236     info <general>: Skipped 1 duplicate messages..
    2024-06-11 00:48:38.585 T:3236  warning <general>: OutputPicture - timeout waiting for buffer
    2024-06-11 00:48:41.886 T:2935     info <general>: JSONRPC Server: New connection added
    2024-06-11 00:48:41.887 T:2935     info <general>: WebSocket: missing Sec-WebSocket-Version
    2024-06-11 00:48:44.300 T:3234     info <general>: CVideoPlayerAudio::Process - stream stalled
    2024-06-11 00:48:46.885 T:2935     info <general>: JSONRPC Server: Disconnection detected
    2024-06-11 00:48:47.361 T:3234     info <general>: CVideoPlayerAudio::Process - stream stalled
  • there is currently no other solution than compiling the ffmpeg plugin yourself. You need to set up a LibreElec Dev System for that, change a config file and have some spare hours CPU time ;)
    If you want to do that i can give you the hints on which screws you need to work to brew ffmpeg 4.4.4 which is working.
