I have a problem with powering off, suspending or restarting libreelec. Whatever option I choose, I'll be stuck with black screen unable to do anything. The only option to start it up again is to pull out the powering cable and plug it back on. It makes my htpc almost unusable
Problem with power options - system won't resume
Shepo_PL -
March 10, 2024 at 4:48 PM -
Please provide a full debug log.How to post a log (wiki)1. Enable debugging in Settings>System Settings>Logging2. Restart Kodi3. Replicate the problem4. Generate a log URL (do not post/upload logs to the forum)
use "Settings > LibreELEC > System > Paste system logs" or run "pastekodi" over SSH, then post the URL link -
Here's the log paste.libreelec.tv/shining-dassie.log
Do you have the same issue, if you don't have the WiFi adapter attached? It seems to make trouble in the log.
Yes, nothing changes with the adapter plugged off
- update to LE 12 Beta
- make sure your BIOS is up-to-date
My bios is outdated but I looked on the internet not long ago how to update it and it turned out it couldn't be done. If I try I'll brick my device.
Installed new update and nothing changed besides the wifi adapter which now is not working
Normally I would investigate that WiFi bug now, but without an updated BIOS it makes no sense.
