Hello all -
I have an X96S TV stick, Amlogic S905Y2 proc. I got it to boot from LibreELEC-AMLGX.arm-11.0.6-box.img.gz, using either the meson-g12a-sei510.dtb or meson-g12a-u200.dtb files - the others kick out a network driver error or don't boot at all.
The problem: the IR remote that comes with this stick does not work from the get-go. I've grabbed the remote.conf file that is recommended in these forums, but since I can't control the device, I can't set up networking, ergo I can't copy remote.conf to /storage/.config!
I was previously playing with CoreELEC on this stick, and had the same issue with the remote. CoreELEC also has a remote.conf file, but with that build you can just copy it to the root of the SD card and it will configure itself on boot. (CoreELEC's S905Y2 build is not working with the WiFi or BT on this stick, so I thought I'd give LibreELEC a try.)
So, how do I get the IR remote working when I don't have network access to the stick?
TIA for any pointers.
