I have LE 11.0.6 on le potato with TL-WN725N wifi adapter, but the wifi doesn't show up as an available network. I only see my wired connection. I have ssh into LE and it seems to recognize the adapter as being connected. How can I make it show up as a option in kodi?
[Le Potato] TL-WN725N WiFi Adapter Issue
hwgoat -
February 17, 2024 at 3:13 AM -
Thread is Resolved
Please provide a full debug log.How to post a log (wiki)1. Enable debugging in Settings>System Settings>Logging2. Restart Kodi3. Replicate the problem4. Generate a log URL (do not post/upload logs to the forum)
use "Settings > LibreELEC > System > Paste system logs" or run "pastekodi" over SSH, then post the URL link -
log files pasted to https://paste.libreelec.tv/direct-chipmunk.log
Feb 16 18:11:03.067888 LibreELEC kernel: r8188eu: module is from the staging directory, the quality is unknown, you have been warned. Feb 16 18:11:03.212474 LibreELEC connmand[513]: wlan0 {create} index 3 type 1 <ETHER> Feb 16 18:11:03.212608 LibreELEC connmand[513]: wlan0 {update} flags 4098 <DOWN> Feb 16 18:11:03.212657 LibreELEC connmand[513]: wlan0 {newlink} index 3 address 14:EB:B6:A9:5E:BF mtu 1500 Feb 16 18:11:03.212695 LibreELEC connmand[513]: wlan0 {newlink} index 3 operstate 2 <DOWN> Feb 16 18:11:03.214879 LibreELEC connmand[513]: Adding interface wlan0 [ wifi ] Feb 16 18:11:03.223865 LibreELEC kernel: usbcore: registered new interface driver r8188euIt looks working from a driver perspective but the interface is in a <down> state. What happens if you do "ifconfig wlan0 up" ?
I get the below response.
ifconfig: ioctl 0x8914 failed: Operation not permitted
I have a hunch the AMLGX image is missing the firmware for the card. Please update to this (LE12) image and test again:
https://chewitt.libreelec.tv/testing/LibreELEC-AMLGX.aarch64-11.80.0.tar
Thanks for the help!! But please forgive my ignorance. How do I create the image from the .tar file?
Is there a tutorial for it?
I am on my windows laptop. I used Win32 Disk Imager 1.0. To write the .tar to SD Card. It said it was successful but the potato won't boot.
Put the .tar file in /storage/.update and reboot to update.
Thanks.
Gave it a try. update seemed to work but still no wifi. new log file url below. It looks like the firmware failed to load.
CodeJan 24 13:57:55.194495 GaragePotato1-LibreELEC kernel: usb 1-2: RTL8188EU rev D (TSMC) romver 0, 1T1R, TX queues 2, WiFi=1, BT=0, GPS=0, HI PA=0 Jan 24 13:57:55.196156 GaragePotato1-LibreELEC kernel: usb 1-2: RTL8188EU MAC: 14:eb:b6:a9:5e:d6 Jan 24 13:57:55.198178 GaragePotato1-LibreELEC kernel: usb 1-2: rtl8xxxu: Loading firmware rtlwifi/rtl8188eufw.bin Jan 24 13:57:55.201246 GaragePotato1-LibreELEC kernel: usb 1-2: Direct firmware load for rtlwifi/rtl8188eufw.bin failed with error -2 Jan 24 13:57:55.203099 GaragePotato1-LibreELEC kernel: usb 1-2: request_firmware(rtlwifi/rtl8188eufw.bin) failed Jan 24 13:57:55.204755 GaragePotato1-LibreELEC kernel: usb 1-2: Fatal - failed to load firmware Jan 24 13:57:55.210624 GaragePotato1-LibreELEC kernel: rtl8xxxu: probe of 1-2:1.0 failed with error -11 Jan 24 13:57:55.210805 GaragePotato1-LibreELEC kernel: usbcore: registered new interface driver rtl8xxxu -
I made a mistake when updating the image last time so the firmware file wasn't included. If you update to the same file again, this time it has the firmware inside. Then share a log again.
I'll add the firmware to official LE12 images in the next set of changes I push (which is overdue). You can use the ones I have in my test share until then. Thanks for reporting back
