Hello!
After many years of using LE I have encountered a problem that I can't solve and I'm totally lost
Suddenly I have no HDMI output on my RPi3 with 11.0.4. Yesterday it worked fine, today it doesn't. When I was going to update to 11.0.5 the screen was blank and TV said no HDMI input. At first I thought the Raspberry was dead, but then I saw that it booted and I could connect to it with ssh.
Anyway, whatever I have tried has failed to work, such as modifying config.txt and trying different PSUs. I also get the same problem with a fresh install of 11.0.5 on a different SD-card... But then I tried 9.2.8 and that version works fine. However, when I did an upgrade of that version to 10.0.4 the problem returned. I also tried some other images and they worked fine as well.
I am totally out of ideas so I hope someone here can help me out
Thank you in advance.
