could you please enable nxp support?
I'm looking for a lvm2 nxp for cubox4x4
hmm no official images
i can try build you a one off if you say what image are you using right now or even better waht build command from that list here https://wiki.libreelec.tv/development/bu…mands-le-12.0.x
feels like it is ARCH=arm DEVICE=iMX6 PROJECT=NXP
version 12.0.1-#241122
download link https://sky42.libreelec.tv/release/12.0/
based on LE 12.0.1 https://github.com/LibreELEC/LibreELEC.tv/tree/12.0.1
changelog
- upstream update
- linux: update to 6.6.63
my source diff https://github.com/LibreELEC/Libr…v:12.0.1-241122
*** for testing only ***
version 12.0.1-#241123-6.12 for Generic-BT2020 only
download link https://sky42.libreelec.tv/release/12.0/G…20/kernel-6.12/
changelog
- based on 12.0.1-#241122
- systemd: update to 255.10
- libva: update to 2.22.0
- gmmlib: update to 22.5.2
- media-driver: update to 24.3.4
- libva-utils: update to 2.22.0
- libdrm: update to 2.4.123
- Generic: options for kernel 6.12
- RTL8192DU: removed, 6.12 uses in tree driver
- RTL8812AU: removed, 6.12 uses in tree driver
- strace: update to 6.12
- linux: update to 6.12 from master
- linux (Generic): .config for 6.12 from master
- linux (Generic): .config enable MD, DM and more encryption
- linux: update to 6.12.1
my source diff https://github.com/LibreELEC/Libr…0.1-241123-6.12
version 12.0.1-#241124 for NXP only
download link https://sky42.libreelec.tv/release/12.0/NXP/
changelog
- linux (NXP): enable MD, DM and more encryption
my source diff https://github.com/LibreELEC/Libr…v:12.0.1-241124
frees these NXP images will not be part of my normal releases. If you want a update i would prefer you build it you self. My source now contains all it needs, but you can ask and i will try to build you one. These NXP images put about 2h more buildtime and 1GB image space on my download server to every release.
Thank you.
It feels like i have to do it by myself anyway, but thank you for kick start
I'd like to cut back a little on the costs for building and hosting my community builds.
For Amlogic, Allwinner, Rockchip and NXP i will only build and host LE releases like 12.0.1.
For Generic and RPi i will continue to build (some times) updates in between e.g. 12.0.1 and 12.0.2.
I will delete from the download server all LE12 images for Amlogic, Allwinner and Rockchip excepct 12.0.0-#240426 and 12.0.1-#240817 (if there is such image).
On the plus side my LE12 releases will also include NXP builds like for the upcoming 12.0.2 as there is at least one user frees .
If you want a build between LE12 releases for any of Amlogic, Allwinner, Rockchip or NXP just ask here and if there is a good enough reason i will build one for you.
version 12.0.2-#250120
for Generic, RPi, Allwinner, Rockchip, Amlogic, NXP
based on LE 12.0.2 https://github.com/LibreELEC/LibreELEC.tv/tree/12.0.2
my source diff https://github.com/LibreELEC/Libr…v:12.0.2-250120
*** attention *** Generic-BT2020 is obsolete use Generic ***
https://sky42.libreelec.tv/release/12.0/Generic/obsolete-Generic-BT2020/README.obsolete.txt
changelog
- upstream update 12.0.2
- Generic: remove device BT2020 (PR24160 is merged)
version 12.0.2-#250122-6.12
for Generic only
should be usefull for testing Intel Xe driver, new Hardware like Meteor Lake or N150
download link https://sky42.libreelec.tv/release/12.0/G…ic/kernel-6.12/
based on my 12.0.2-#250120 https://github.com/sky42src/LibreELEC.tv/tree/12.0.2-250120
my source diff https://github.com/sky42src/Libre…0.2-250122-6.12
changelog
- systemd: update to 255.17
- gmmlib: update to 22.5.5
- media-driver: update to 24.4.4
- libdrm: update to 2.4.124
- kernel-firmware: update to 20250109
- bcm_sta: removed, droped in master
- linux: update to 6.12.10 from master
- linux (Generic): .config for 6.12.10 from master
version 12.0.2-#250220
for Generic, RPi4, RPi5
my source diff https://github.com/LibreELEC/Libr…v:12.0.2-250220
changelog
- upstream update
- linux: update to 6.6.78
- kodi: update to bf9b0c4
- kodi: pretty GIT_VERSION
- sky42: reorganized view mode hack, +tag (not in my community build)
- json-c: update to 0.18 from master (0.17 gh sha256 fail)
version 12.0.2-#250221-6.12
for Generic only
should be usefull for testing Intel Xe driver, new Hardware like Meteor Lake, N150 or maybe even Lunar Lake
based on https://github.com/sky42src/LibreELEC.tv/tree/12.0.2-250220
my source diff https://github.com/sky42src/Libre…0.2-250221-6.12
changelog
- kernel-firmware: update to 20250211
- intel-ucode: update to 20250211
- iwlwifi-firmware: update to fb888a7
- linux: update to 6.12.15 from master
THANK YOU SO MUCH for this. Working really well on GMKtek G3 Plus.
version 12.0.2-#250407
my source diff https://github.com/LibreELEC/Libr…v:12.0.2-250407
250407
- upstream update
- drop json-c update
- kodi: update to ccf501f
- linux: update to 6.6.86
version 12.0.2-#250415-6.12
for Generic only
should be usefull for testing Intel Xe driver, new Hardware like Meteor Lake, N150, N250 or maybe even Lunar Lake
based on https://github.com/sky42src/LibreELEC.tv/tree/12.0.2-250407
my source diff https://github.com/sky42src/Libre…0.2-250415-6.12
250415 changelog
- based on release: 12.0.2-#250407
- kernel-firmware: update to 20250410 from master
- intel-ucode: update to 20250211 from master
- iwlwifi-firmware: update to 95ddbdd from master
- linux: update to 6.12.23 from master
- linux (Generic): .config for 6.12.23 from master
version 12.0.2-#250416-6.12
for Generic only
This version is build to check if Realtek NIC 8125D is working e.g. in the NUC 14 Essential.
On my Z100 with 8125B the NIC is still working (since yesterday).
I needed to disable some sourcecode from the 6.13.11 r8169 driver to build it with 6.12, but i think it should work without.
based on https://github.com/sky42src/Libre…0.2-250415-6.12
my source diff https://github.com/sky42src/Libre…0.2-250416-6.12
250416
- linux (Generic): backport r8169 driver from 6.13.11
Like your Builds for my GMKtek G3 Plus, N150 - working great - Thx
Any chance to get a new Generic ?
So far there is no really good reason to build a new Generic.
Yesterday a openssl update was merged and for that I will most likely spin up a new release.
