Libreelec 11.0.4 problem connect wifi
  • Hello good,
    I have version 11.0.4 "generic" on a Lenovo M710q with the following wifi hardware:
    • Wifi --> Intel Wireless 3165 (rev 79)
    The problem is when connecting to the Wi-Fi that it almost never connects and I have to restart the system several times until it detects the Wi-Fi and connects. I have also tried, within the network configuration, to disable Wi-Fi and turn it back on to see if it detects Wi-Fi, but it doesn't work. I have also tried to modify the time it takes libreelec to start until it connects to the Wi-Fi (30 seconds) but it doesn't work either.
    With version 11.0.3 I did not have this issue and libreelec connected automatically and on the first try.
    I don't know if this happens to anyone else, but as I say, in the previous version, this problem did not exist, it all started with the latest version (11.0.4).
    Where is the problem?
    Thank you
    PD: I have tried to put a log of the libreelec startup, but when I restarted the system, as it could not be otherwise, it connected to the Wi-Fi the first time :cursing:
    PD: Now I see this message on start the system "Failed to start iwf.service" and not have wifi
    Edited once, last by Vctrsnts (January 2, 2024 at 11:45 AM).
