Hi everybody,
I use LibreELEC since version 9.2 and everything has always worked so far.
But for a few weeks now the kodi addon "HD Austria" (https://kodi.tv/addons/nexus/plugin.video.hdaustria/) is not working any longer.
I am running LibreELEC 11.0.3 (updated from 11.0.2 updated from 10.0) on a raspberry pi 3b (2015).
To reproduce the problem and to avoid interactions with other addons I did a fresh installation of LibreELEC 11.0 (not 11.0.3).
Then I installed only HD Austria addon and its required dependencies InputStream Adaptive and InputStream Helper.
With InputStream Helper I installed Widevine (hana, 15604.57.0).
Afterward I tried to use HD Austria but its the same problem as with my default system.
According to the log file, the following errors occur:
- critical <general>: [script.module.inputstreamhelper] ['ldd', '/storage/.kodi/cdm/libwidevinecdm.so'] cmd failed.
- critical <general>: [script.module.inputstreamhelper] Failed to check for missing Widevine libraries.
- error <general>: GetDirectory - Error getting /usr/lib/kodi/addons/inputstream.adaptive/
- error <general>: CCurlFile::CReadState::FillBuffer - (0x5bc3f9c0) Failed: HTTP returned code 403
- error <general>: CCurlFile::Open - <https://license.solocoo.tv/wv?c=m7be2%3A2%......
- error <general>: AddOnLog: inputstream.adaptive: License server returned failure
Running command ldd on libwidevinecdm.so results in: "error while loading shared libraries: /storage/.kodi/cdm/libwidevinecdm.so: DT_RELR without GLIBC_ABI_DT_RELR dependency"
As far as I found out, I was not the first to have this problem: https://github.com/LibreELEC/LibreELEC.tv/issues/8207
According to this post and HiassofTs comment, I am also using ORF TVThek Addon and it works without errors.
I am also using Joyn Addon (with its dependencies InputStream Adaptive and InputStream Helper) and it also works without errors.
It seems that some addons have problems and others not but the error messages are from inputstreamhelper and inputstream.adaptive.
Thanks for every support.
