Hi everyone,
this is my first message, my name is Max and I write from Italy, nice to meet you
I have an old Minix Neo U1 which, until an hour ago, worked perfectly with an old version of Libreelec.
Obviously (and I still wonder "why did I do it? " I thought I'd update it and unfortunately Libreelec doesn't start anymore...
I downloaded the LibreELEC-AMLGX.arm-11.0.1-box.img.gz image and wrote it to the SD card with the LibreELEC USB-SD Creator tool.
Then I changed the uEnv.ini file by inserting:
dtb_name=/dtb/meson-gxbb-minix-neo-u1.dtb
I inserted the SD into the Minix, held down the key for 6 seconds, the android logo appears and anfer if it shows the error message
*** Error in mount_flash: mount_common: Could not mount UUID=1803-1159
In attach a photo of the error.
Obviously I've been looking for info on the net but I can't find anything useful.
Could you please give me a hand?
Thank you!!!
