I am working on bringing up a build for an orangepi one (1GB RAM variant). Everything has gone swimmingly except for my efforts to enable the USB OTG port in host mode. I've gathered from other discussions about this issue that the path of least resistance is to reconfigure usb_otg 'dr_mode = "otg"' to 'dr_mode = "host"'.
I imagine there are multiple ways to attack this issue, but my first instinct was to put a .patch file in projects/Allwinner/devices/H3/patches/linux/ which just modifies that single line in the orangepi zero's dts. So, I created the patch, and ran a clean build. Looking through the logs, I see that the build ran through all the other .patch files in that subdirectory, but didn't even attempt to process my patch. Of course, in the end, the dtb file did not have my intended changes.
My next attempt was to put the exact same .patch file in projects/Allwinner/patches/linux instead. Clean build, and the log showed that the patch was taken and applied. And the dtb was modified as I intended.
Is it reasonable that putting the patch file in one subdirectory is automatically picked up and included in the build, but not in the other subdirectory? Is there anything extra I should expect to have to do, when I create a new patch specifically in projects/Allwinner/devices/H3/patches/linux?
