Strange crontab problem
  • I have cron enabled in settings.
    I have verified the cron is working by creating a crontab entry
    * * * * * * date >/tmp/date.txt
    And indeed /tmp/date.txt gets the time and date written once per minute.
    However when I change the crontab to
    * * * * * * /storage/usr1/kenc/temps.sh >/tmp/temps.sh.txt 2>&1
    where temps.sh contains
    date
    The file is chmod 755 and runs when executed from an interactive shell.
    I've tried with and without a shebang in the file.
    The script doesn't run.
    Confusingly, /tmp/temps.sh.txt contains:
    /bin/sh: backup: not found
    Any ideas?
    Edited once, last by poodad (October 3, 2022 at 6:32 PM).
  • does it work like this
    * * * * * * echo $(date) >/tmp/temps.sh.txt
    edit : yes you tryed already
    second tought..
    in /storage/usr1/kenc/temps.sh
    change date to
     echo $(date)
