LE11 RPi IR-Keytable
  • Do you still have lircd.conf around? If yes, this is expected. You can either use lircd or ir-keytable but not both at the same time.
    Yeah the addon for Argon40 case fan control adds it. Without add on I cant control the fan speed and the manual script method no longer works on LE11 due to Python changes. I will see if I make the add on not add the file on reboot.
