I'm sorry, but I didn't understand what you need. Could you please be more specific about your request?
Did something work before and now it doesn't?
In any case, I need a lot more information to help.
OLEDproc add-on
LuRu -
April 25, 2022 at 5:02 PM -
Thread is Resolved
Is it possible to run this script using your addon?
I need to see the remaining HDD space on OLED
Python
Display More#!/usr/bin/env python import re import time import busio import subprocess from threading import Timer from board import SCL, SDA from PIL import Image, ImageDraw, ImageFont import adafruit_ssd1306 i2c = busio.I2C(SCL, SDA) disp = adafruit_ssd1306.SSD1306_I2C(128, 32, i2c) disp.fill(0) disp.show() width = disp.width height = disp.height image = Image.new("1", (width, height)) draw = ImageDraw.Draw(image) draw.rectangle((0,0,width,height), outline=0, fill=0) #draw.rectangle((0, 0, width, height), outline=0, fill=0) padding = -5 top = padding bottom = height - padding x = 0 # Load default font. font = ImageFont.truetype('/usr/local/bin/pistatus/icon/Ubuntu-R.ttf', 18) # Variables cpu_temp = 0 date_text = "01.01.1970" time_text = "00.00.00" hdd1_free = 0 hdd1_percent = 0 hdd2_free = 0 hdd2_percent = 0 screen_no = -1 def get_date_time(): global date_text global time_text cmd = "date +%H:%M" time_text = subprocess.check_output(cmd, shell = True).decode("utf-8") cmd = "date +%d-%m-%Y" date_text = subprocess.check_output(cmd, shell = True).decode("utf-8") t = Timer(10, get_date_time) t.start() get_date_time() def get_hdd(): global hdd1_free global hdd1_percent global hdd2_free global hdd2_percent cmd = "df -h | awk '$NF==\"/mnt/hdd\"{printf \"HDD1: %s\", $5}'" hdd1_percent = subprocess.check_output(cmd, shell = True).decode("utf-8") cmd = "df -h | awk '$NF==\"/mnt/hdd\"{printf \"FREE: %sB\", $4}'" hdd1_free = subprocess.check_output(cmd, shell = True).decode("utf-8") cmd = "df -h | awk '$NF==\"/mnt/hdd2\"{printf \"HDD2: %s\", $5}'" hdd2_percent = subprocess.check_output(cmd, shell = True).decode("utf-8") cmd = "df -h | awk '$NF==\"/mnt/hdd2\"{printf \"FREE: %sB\", $4}'" hdd2_free = subprocess.check_output(cmd, shell = True).decode("utf-8") t = Timer(2, get_hdd) t.start() get_hdd() def get_cpu_temp(): global cpu_temp cmd = "vcgencmd measure_temp" cpu_temp = subprocess.check_output(cmd, shell=True).decode("utf8") #return float(re.findall(r'\d+\.\d+', cpu_temp)[0]) t = Timer(5, get_cpu_temp) t.start() get_cpu_temp() def raise_screen_no(): global screen_no screen_no += 1 if screen_no > 5: screen_no = 0 t = Timer(4, raise_screen_no) t.start() raise_screen_no() while True: draw.rectangle((0,0,width,height), outline=0, fill=0) if screen_no == 1: #cpu°C image = Image.open("/usr/local/bin/pistatus/icon/temperature.bmp").convert("1") draw = ImageDraw.Draw(image) font = ImageFont.truetype('/usr/local/bin/pistatus/icon/Ubuntu-R.ttf', 30) draw.text((x, top+5), str(cpu_temp[5:9]+'°C'), font=font, fill=255) elif screen_no == 2: #hdd1 /dev/sda image = Image.open("/usr/local/bin/pistatus/icon/disk.bmp").convert("1") draw = ImageDraw.Draw(image) font = ImageFont.truetype('/usr/local/bin/pistatus/icon/Ubuntu-R.ttf', 18) draw.text((x, top), str(hdd1_percent), font=font, fill=255) draw.text((x, top+20), str(hdd1_free), font=font, fill=255) elif screen_no == 3: #hdd2 /dev/sdb image = Image.open("/usr/local/bin/pistatus/icon/disk.bmp").convert("1") draw = ImageDraw.Draw(image) font = ImageFont.truetype('/usr/local/bin/pistatus/icon//Ubuntu-R.ttf', 18) draw.text((x, top), str(hdd2_percent), font=font, fill=255) draw.text((x, top+20), str(hdd2_free), font=font, fill=255) else: #time font = ImageFont.truetype('/usr/local/bin/pistatus/icon/Ubuntu-R.ttf', 39) draw.text((x, top), str(time_text), font=font, fill=255) # Display image. disp.image(image) disp.show() time.sleep(1)
Unfortunately, I don't know of such a possibility (unless quite extensive modifications are made). The OLEDproc add-on can only display the information it receives from the XBMC LCDproc add-on.
