Rpi4 Libreelec 10.0.1 no sound through Pi's audio jack or Bluetooth
  • Raspberry Pi 4 arm: LibreELEC 10.0.1 KODI
    My HDMI monitor doe not have speakers connected.
    I have a portable speaker plugged into the Raspberry Pi's stereo jack; but no sound.
    I also tried connecting a Blue Tooth Headset that does show up as connected in Libreelec, but no sound.
    Kodi plays everything over the local LAN when connecting with a web browser.
    My Smart TV connects and plays content OK.
    I just can't get any sound from the Pi audio port, nor from blue tooth headphones.
    I had these two things working once but it all eludes me now.
    I'm lost and need Help!
    Also, if there is a setting needed in a config file I don't know how to get to a Terminal window for editing config files
    Thank you.
  • To enable the audio jack on RPi 4B in LibreELEC 10.x you need to:
    - edit the /flash/config.txt file ( see https://wiki.libreelec.tv/configuration/config_txt ), use Putty terminal to connect LibreELEC SSH console ( https://www.hostinger.com/tutorials/how-to-use-putty-ssh ).
    - add this line to config.txt: dtparam=audio=on
    - reboot LibreELEC
    - in Kodi GUI set the Audio output device in Settings - System - Audio menu to ALSA:bcm2835 Headphones, bcm2835 Headphones
    You should see the connected BlueTooth Headset there as well so it should work if you set it as Audio output device.
  • Thank you!
    Adding that line did make available and the external speaker does connect...
    the Plus (+) and Minus (-) sign controls the volume.
    All is working.
    Very Happy!
    Thank you
    Edited once, last by Angelo327 (February 6, 2022 at 9:06 PM).
