Hello,
I was using a T95x (s905x) box and mapped the included NEC Amlogic remote scancodes to an All In One remote. This all worked fantastic! I since switched to a RPI4 and now using the ir-keytable with keycodes. Was able to map most of the old scancodes to the proper keycodes except for a few that I'm not seeing a corresponding keycode. Here are the scancodes I need some help with finding the correct keycodes:
- Enable/Disable subtitles
- Video zoom / cycle through the different aspect ratios
- Audio delay (sometimes media audio is off)
- Video (this button would jump directly to whatever is playing if I were in an EPG, Menu, Settings, etc...)
I had these mapped to the Red, Green, Orange, Blue buttons respectively.
Appreciate the help!
