Problems with flirc2 on Mac OS
  • Anyone else had the same problem?
    Downloaded .dmg - run the installer (turned off security as flirc.tv not apple approved) tried to launch the app for the app folder.
    Nothing!
    repeated the download->install->launch process at least three times - no go.
    Help
    Steve
    PS. I should perhaps have mentioned that I am wanting to use my new flircUSB2 with LibrELEC+Kodi on a Pi3
    Edited once, last by wimphot (October 30, 2021 at 9:01 PM).
  • Hey Steve, sorry you are having trouble. What OSX version is this?
    There isn't an install process, once you download the app, you drag to your applications folder.
    I don't know why I can't sign the app properly. However, I'm in the middle of a new product, much of the work I'm doing will be for flirc usb as well.
    Thanks Steve.
