Modifying /flash/distroconfig.txt is the wrong approach - it will be replaced on every update. Commenting out the "include distroconfig.txt" in /flash/config.txt and replacing that with custom dtoverlay or other settings is even more dangerous as it could brick your installation on an upgrade - the stuff in distroconfig.txt is essential.
If you need to force a video mode you should add a video= parameter to /flash/cmdline.txt, eg video=HDMI-A-1:640x480M@60 - see the kernel docs for more info modedb default video mode support — The Linux Kernel documentation
It would help even more if you post why you need to change settings, which settings they are and provide pastekodi logs - then we would have a chance to look into it and if there's an issue we could fix it. If you don't report issue details and post logs they will never get fixed.
