After installing dvb-latest rebooted then :
LibreELEC (dtech): 9.2.8.18 (Generic_S905.arm)
LibreELEC:~ # dmesg | grep -i dvb
[ 7.781016@2] kernel-overlays-setup: processing conf /storage/.cache/kernel-o verlays/50-driver.dvb.dvb-latest.conf
[ 7.832158@2] kernel-overlays-setup: added modules from /usr/lib/kernel-overl ays/driver.dvb.dvb-latest/lib/modules/3.14.29
[ 13.176518@1] dvb_meson dvb.51: Found i2c-2 adapter: aml_i2c_adap2
[ 13.176532@1] dvb_meson dvb.51: ts0: parallel
[ 13.176621@1] dvb_meson dvb.51: ts0_control: 0x0
[ 13.176643@1] dvb_meson dvb.51: GPIO fec_reset0: 217
[ 13.176652@1] dvb_meson dvb.51: GPIO power_ctrl0: 215
[ 13.176675@1] dvb_meson dvb.51: dev_name=wetek-dvb
[ 14.395375@1] dvb_meson dvb.51: DVB demod detection for i2c-2 (aml_i2c_adap2) ...wetek-dvb
[ 15.615375@2] dvb_meson dvb.51: Checking for AVL6211 DVB-S/S2 demod ...
[ 15.615732@2] i2c i2c-2: AVL6211+AV2011 DVB-S/S2 successfully attached
[ 15.615743@2] dvb_meson dvb.51: Total DVB modules found: 1
[ 15.618015@2] dvbdev: DVB: registering new adapter (dvb_meson)
[ 15.629676@2] dvb_meson dvb.51: DVB: registering adapter 0 frontend 0 (Availi nk AVL6211+AV2011 DVB-S/S2)...
[ 15.631206@2] Meson DVB frontend(s) registered successfully.
LibreELEC:~ # dvb-fe-tool -a 0 --verbose
Found dvb demux device: dvb0.demux0
path: /dev/dvb/adapter0/demux0
sysfs path: /sys/devices/dvb.51/dvb/dvb0.demux0
bus addr: platform:dvb.51
Found dvb demux device: dvb0.demux1
path: /dev/dvb/adapter0/demux1
sysfs path: /sys/devices/dvb.51/dvb/dvb0.demux1
Found dvb demux device: dvb0.demux2
path: /dev/dvb/adapter0/demux2
sysfs path: /sys/devices/dvb.51/dvb/dvb0.demux2
Found dvb dvr device: dvb0.dvr0
path: /dev/dvb/adapter0/dvr0
sysfs path: /sys/devices/dvb.51/dvb/dvb0.dvr0
Found dvb dvr device: dvb0.dvr1
path: /dev/dvb/adapter0/dvr1
sysfs path: /sys/devices/dvb.51/dvb/dvb0.dvr1
Found dvb dvr device: dvb0.dvr2
path: /dev/dvb/adapter0/dvr2
sysfs path: /sys/devices/dvb.51/dvb/dvb0.dvr2
Found dvb frontend device: dvb0.frontend0
path: /dev/dvb/adapter0/frontend0
sysfs path: /sys/devices/dvb.51/dvb/dvb0.frontend0
Found dvb net device: dvb0.net0
path: /dev/dvb/adapter0/net0
sysfs path: /sys/devices/dvb.51/dvb/dvb0.net0
Found dvb net device: dvb0.net1
path: /dev/dvb/adapter0/net1
sysfs path: /sys/devices/dvb.51/dvb/dvb0.net1
Found dvb net device: dvb0.net2
path: /dev/dvb/adapter0/net2
sysfs path: /sys/devices/dvb.51/dvb/dvb0.net2
Selected dvb frontend device: dvb0.frontend0
Device Availink AVL6211+AV2011 DVB-S/S2 (/dev/dvb/adapter0/frontend0) capabiliti es:
CAN_2G_MODULATION
CAN_FEC_1_2
CAN_FEC_2_3
CAN_FEC_3_4
CAN_FEC_4_5
CAN_FEC_5_6
CAN_FEC_6_7
CAN_FEC_7_8
CAN_FEC_8_9
CAN_FEC_AUTO
CAN_INVERSION_AUTO
CAN_QPSK
CAN_RECOVER
DVB API Version 5.11, Current v5 delivery system: DVBS
Supported delivery systems:
[DVBS]
DVBS2
SEC: set voltage to OFF
ERROR FE_SET_VOLTAGE: Operation not permitted
Display More
Same error in CE : ERROR FE_SET_VOLTAGE: Operation not permitted
