How can I prove to someone that the builds are on kodi 18 or that kodi 18 runs python2? For some reason, I can not run this, or any other kodi parameter like kodi --help, on le.
dtech -
February 7, 2021 at 2:33 PM -
Thread is Resolved
Thanks dtech and libreelec team, for your efforts.
Reporting to say that the LibreELEC-Generic_S905.arm-9.2.8.13 is working on my Nexbox MXQ PRO with Amlogic S905 SoC. Installed to internal emmc storarage. Wifi was fine from the first boot (box has Realtek 8189etv) but Ethernet was not working until I used gxbb_p201.dtb as dtb.img. Cheers.
Display More
Now I see you are trying to update with an S805 (m8b) image, even though you have an S905 (gxbb) device. This is not going to be good.
If you update your S905 with the HD18Q image, it is guaranteed to never boot again after you restart your device.
And chewitt is also right, because in Leia versions (9.0/9.2) for Amlogic S905x the kernel is 64-bit, but Kodi is only 32-bit.
I think you need to look for another sd card and create a clean install with this image: LibreELEC-MXQ-4K-Pro_2G.arm-9.2.8.3.img.gz.
This is the correct dtb for your device: gxbb_p200_1G_mxq_pro_4k.dtb, it should be renamed to dtb.img and overwrite the original.
this is my first post i have seen the MODERATOR dtech being so kind with everyone and solved many problems so i want to take my chance
my problem is i have Pandora 3D game box which is Amlogic CPU: S812 and MICRON NAND (29F16G09CBA) CHIP i was playing with its partitions to enable some tweak and bricked it..now i am in a situation where i have ADB backup of all partitions but lost all partitions (image1) (sda&sda1 is the usb pendrive attached in a machine)and i dont have the factory firmware for it to restore it to a original position
please suggest me something
i can access recovery(image2) when i burn card with my uboot.bin just recovery with root access but partitions are gone
Would the goal be to restore the original environment or to install LibreELEC?
I have an idea for the second, but the first needs to be investigated.
Just bring it back to life either LibreElec or original no problem at all
Because I am tired trying roms after roms
I have one more information when I give command on adb root shell
#cat /proc/device-tree/amlogic-dt-id
#m8m2_n200_1g <———-result is this -
If it's not the factory one and there's no backup, it's not exactly a good base.
m8m2_n200_1g
Then there is a problem, because I don't have a 1GB image for S812, only for S802 (MXIII-1G).
There was a test kernel for the 1GB box, it might work with that (but it was not made for the latest image):
PostRE: Legacy v9.2 (LTS) builds for Amlogic S805/S8X2, S905/S912 and all WeTek boxes
Please try the n200 image with this kernel:
https://libreelec.dtech.hu/_TEST_/MXIII-G_1GB-kernel/
If it starts with this, your Android is unfortunately only lying that you have 2GB of RAM, but in fact it only manages 1GB.
dtechMarch 5, 2023 at 9:57 AM -
I do have a Adb Backup of my machine
Boot
Recovery
Misc
System
Cache
Date
Mtdblock01— which is u-boot actually
Mtdblock0—-which is Env config actualky
dtechMarch 5, 2023 at 9:57 AM how to test it? i mean how to make a single file for usb_burning_tool? or something which can fix the partitions of the NAND and i am not after latest version i am satisfied with the 4.4 kitkat which was working smooth before it was bricked
Unfortunately, I'm not an expert in ADB operations or Android-based tricks, I think bumerc can help you more with that.
Amlogic USB Burning Tool also requires a specific ROM format, but my images are not firmware/ROM images, only OS images (kernel + rootfs), so these do not contain any manufacturer-specific partitions. (Except M8S+ and WeTek images!)
Is there a solution which can restore the partition table like this?the pic below a screenshot before brick
It's probably possible, but I don't know how, that's why I wrote this:
Hi dtech, I'd like to thank you for the work you have done here, and to report that your S805 HD18Q build works really well on my HTV3 Android box. It's almost perfect, and I have figured out how to fix some of the issues I encountered. I will list the issues I ran into, what I was able to fix, and some other notes in case anyone else with this box ends up reading this post.
1. This is the remote.conf that works for my box, maybe you can add it to the list of supported remotes:
htv3-remote.conf
Display More#********************************************************************************************************* #this file is configuration for each factory remote device # work_mode 0 :software mode 1 :hardware mode # repeat_enable 0 :disable repeat 1 :enable repeat # # factory_code each device has it's unique factory code. # pattern:custom_code(16bit)+index_code(16bit) # examble: 0xff000001 = 0xff00(custom code) 0001 (index) # # release_delay unit:ms.release will report from kernel to user layer after this period of time # from press or repeat triggered. # # debug_enable 0 :debug disable 1 :debug enable # # SW MODE: # bit_count how many bits in each frame # tw_leader_act time window for leader active # tw_bit0 time window for bit0 time. # tw_bit1 time window for bit1 time # tw_repeat_leader time window for repeat leader # REG # reg_base_gen set value for PREG_IR_DEC_BASE_GEN # reg_control set value for PREG_IR_DEC_CONTROL # reg_leader_act set value for PREG_IR_DEC_LEADER_ACTIVE # reg_leader_idle set value for PREG_IR_DEC_LEADER_IDLE # reg_repeat_leader set value for PREG_IR_DEC_REPEAT_IDLE # reg_bit0_time set value for PREG_IR_DEC_BIT0_TIME #************************************************************************************************************* # sowell NEC remote * MBX H.TV 3 # factory_code = 0xff800001 work_mode = 0 repeat_enable = 1 repeat_delay = 130 repeat_peroid = 120 release_delay = 20 debug_enable = 1 reg_control = 0xfbe40 # fn_key_scancode = 0x40 left_key_scancode = 0x03 right_key_scancode = 0x02 up_key_scancode = 0x00 down_key_scancode = 0x01 ok_key_scancode = 0x1f # pageup_key_scancode = 0x5a # 0x04 pagedown_key_scancode = 0x5f # 0x1b # mouse_begin 0 0x03 1 0x02 2 0x00 3 0x01 mouse_end # key_begin 0x0a 116 # POWER 0x0d 113 # MUTE 0X51 240 # GOTO 0x5d 114 # VOL - 0x58 115 # VOL + # 0x1f 28 # DPAD_CENTER 0x00 103 # DPAD_UP 0x01 108 # DPAD_DOWN 0x03 105 # DPAD_LEFT 0x02 106 # DPAD_RIGHT # 0x11 2 # 1 0x12 3 # 2 0x13 4 # 3 0x14 5 # 4 0x15 6 # 5 0x16 7 # 6 0x17 8 # 7 0x18 9 # 8 0x19 10 # 9 0x10 11 # 0 0x5b 52 # DOT 0x08 14 # DEL # 0x1a 46 # MENU 0x1c 158 # EXIT 0x1b 172 # HOME 0x04 23 # INFO # 0x5a 109 # P- 0x5f 104 # P+ # 0x05 164 # RED - Play/Pause 0x09 18 # GREEN - EPG 0x42 24 # YELLOW - Codec info 0x43 20 # BLUE - Subtitle key_end # repeat_key_begin 0x5d 114 # VOL - 0x58 115 # VOL + 0x00 103 # DPAD_UP 0x01 108 # DPAD_DOWN 0x03 105 # DPAD_LEFT 0x02 106 # DPAD_RIGHT 0x08 14 # DEL repeat_key_end2. I had to enable "force suspend instead of poweroff" in the system settings, otherwise the remote control would not turn the box on. I know it's explained on your opening post, but I figured I'd mention it here in case someone with the same box reads it.
3. This box has a led on the front. On Android, the LED turns blue when powered on, and red when powered off. On LibreElec it was just always blue. I noticed it worked on Lakka 2.x, so I looked for differences between LibreElec and Lakka S805 config, and I noticed Lakka had this led on /sys/class/leds/m201_costdown::front/.
I set CONFIG_LEDS_M201_COSTDOWN=y and built the HD18Q image using your source code and it is now working as intended. https://github.com/dtechsrv/Libre….arm.conf#L3201Would you consider enabling this for S805 on the master branch?
4. This box has a breathing light on top of the box. On Android, it's red when the internet is disconnected, and blue when it is connected, and it's turned off when the box is powered off. There's also an option on the settings page to turn on the "breathing light" mode, which puts it to fade in and out while cycling through the colors.
On LibreElec, it's purple on boot, and cyan once it's booted. When M201_COSTDOWN led is enabled (see point 3 above), then it's green when the power is on and cyan when the power is off. This is the only issue I have not yet been able to solve on my own. I'd like to have the same behavior as on Android, but I can't figure out how to control it. On Android there's nothing listed under /sys/class/leds/, and I have not found any clues inspecting the motherboard. I am a newbie when it comes to this, so it's very possible I may have missed it. Any pointers on how to dig deeper into this breathing light issue would be greatly appreciated.
5. I installed the zach-morris addon repository from the LibreElec Alpha repository, and then tried to install the IAGL program addon, but it failed saying it requires python 3. As it turns out, plugin.program.iagl-2.1.8.zip is the last version that works with python 2, but it's not available on the repository. I had to install it from zip, but then it worked fine.
6. The addon libretro MESEN for NES crashes when opened. QuickNES is sluggish and has the wrong colors. Nestopia works very well on the games I tested.
7. PCSX ReARMed was a bit sluggish on the default settings, but it runs pretty smoothly with PSX cpu clock set to 63 instead of the default of 57.
8. The box has a reset button on the bottom of the board instead of the AV port, but it does not always work to bring up the boot loader. However, pressing the MENU button on the remote repeatedly during boot works pretty consistently.
I am attaching some images of the box here:
dtechMarch 5, 2023 at 9:57 AM is there any Amlogic_burning_tool *.IMG tested on any box (s812)which exactly match with m8m2_n200_1g ?Available somewhere what my idea is just to restore the partitions... no matter what the result is
Sorry for not replying until now, I've been away from my build environment for quite a few days now, but I'll review your suggestions on what can be implemented in the next version. I would definitely like to ask for your patience for a few days.
This does not make much sense, because the dtb id will not be enough, the size of the partitions can be different per manufacturer and/or model, so it makes no sense to flash a "similar" ROM.
You should get the factory one, either from the manufacturer, or find someone who has the same device on a dedicated Android forum and ask them to make a raw flashdump of the box and upload it somewhere.
We here on this forum, but especially on this topic, probably won't be able to help you.
I came across the post
linux-meson/arch/arm/boot/dts/amlogic/meson8m2_n200_1G.dtd at master · endlessm/linux-mesonContribute to endlessm/linux-meson development by creating an account on GitHub.github.com
Which is exactly matching my configuration if somehow I could getmeson8m2_n200_1G.dtb
I request anyone arrange me the file atleast I can try to get back my machine I can repack the backup with these files
Please I request anyone if can be arranged DTB atleast I can try
Another user seems to have this file alsoArmbian for Amlogic S805 and S802/S812forum.armbian.com
I hope someone still have that -
No rush, I am glad I got this far, and like I said in my post, I was able to build the image myself with the M201_COSTDOWN led enabled, so the box is working here. I can watch HDHomeRun and play retro games, which is more than I expected from a 8 years old Chinese box that has been gathering dust in the garage for years at my parents place.
I have unplugged the breathing light cable from the board for now so it's not always on, but I'd appreciate any pointers on that when you have time. It's a silly feature, but it's there, so I'd like to make it work if I can.
I still don't understand what you want to achieve with a single dtb file, but a few things are good to know:
- The 3.10 kernel cannot load external dtbs from a file, only the version integrated into the kernel, so the dtb itself is not enough.
- Android (factory) and LE/Armbian (universal) dtbs are not the same, the latter almost always lack the static partition table.
- The dtb you are looking for only says that it is for a device equipped with an S812 SoC and 1GB of RAM. There are quite a few such boxes.
I would like to ask you that since you want to restore the factory environment, you can either open a new topic here on the forum, or inquire on an Android-specific forum. I would be very happy to help, but unfortunately I indicated before that I can't, so all your requests/questions about restoring the original state are offtopic from now on.
