can you unplug the stick, start your HTPC, wait till it booted
plug the stick in again and run dmesg | paste again ? (so we see what happens after the stick was plugged in)
it was not detected, not sure what happens
Here u have the log after boot and then plug in
The required patch of post 4 is not included into kernel 5.10.
Not atm or will not be?
hmm not sure why I thought it is in 5.10, it should work at Kernel 5.11 and newer out of the box
I can backport the changes, that should work easily.
Thats your decision, because it's your work. I just want to help.
CvH I've already prepared and build tested the patch, "only" need to push the PR.
can you try https://cvh.libreelec.tv/test/rpi/Libre…-Nova-HD.img.gz
If it works for umrotzer we can include it at LE10, better to have a runtime test too
OK tested it. Recognized the tuner and scans all muxes. Tested on 4.3 alpha tvheadend.
Nice so I pr a fix for LE10, so 10.0.2 will have it included (10.0.1 likely not)
Final LE 10.2/11 have it included anyway.
OK thats nice
Is anyone able to provide me an image for the raspberry pi 3 lattest possible version on Le 11 or le 10 with the updated drivers like on the le 9 build?
I would do it myself, but I have absolutely no clue how and cvh no longer response on our pm conversation. That's why I ask.
