Hello,
I have a MCE remote (HA-IR01SV) that works perfectly with LibreElec, however when I use my Harmony Hub remote, most buttons work except the "Exit" and "Menu" buttons (which I am wantingto have mapped to "Back" and "Context Menu", respectively)
In my Harmony software, I have the "Microsoft MCE Keyboard" and "Microsoft Windows Media Center SE" added as devices. When I try to map *anything* to the "Exit" or "Menu" keys, nothing registers (I run 'ir-keytable -t' and see nothing; same when I run 'irw'). Oddly, if I try to map, say "C" (for "Context Menu") from the "Microsoft MCE Keyboard" to any other key which already works with something else, nothing registers when I press it.
I should note that the actual MCE remote I have works without issue, and when I was running Kodi on Ubuntu up to about 3-4 months ago, the Harmony Remote was working perfectly as well (i.e., "Menu" was working as the Context menu)
I have edited my 'keyboard.xml' file in /http://storage.kodi/userdata/keymaps/keyboard.xml to add '<menu>C</menu>' to the '<keybaord></keyboard>' section under "Global", and even restarted the whole machine, but still nothing registers.
Any insight or advise greatly appreciated! ![]()
Thanks, in advance.
