Hardware Plan for a new device with USB-SSD and USB-DVB-T/C ? / TvHeadend
  • Hello to all,
    I plan to setup a new device, and I wanted to ask you, which components work best with kodi.
    I thought of using a raspberry pi, but a different device would be ok also. I want to use tvheadend, and use it as a videorecorder.
    If it was a raspi, which dvb-c/t device gives the best results? which usb3-sata adapter is your recommendation for use with a rpi?
    Or better use a different HW Base? I would prefer it, if automatic power-up and power-down for planned recordings would work...
    Thank you,
    Stefan
