Increase volume in analog audio in RPi4
  • Hello,
    I have a Raspberry Pi 4/2GB with the latest stable release from LibreELEC.
    I use Kodi mostly for audio. I have a stereo amplifier connected via the RPi4 3.5mm jack, and I have a soundbar connected through HDMI.
    When I use the analog audio I have to toggle the volume very high on my amplifier; it seems that the output signal is very low. The problem is that if I or one of my family switches to CD or other sources, the volume is far too high ... Is there a way to adjust/increase output volume on analog output?
    Uh, and just for sake of clarity: Yes, of course I am aware that one can toggle audio in Kodi itself; I usually have it on "maximum" and then toggle the amp.
    Thanks!
    Eriol
